Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Now that the outer door panel is removed, you can open the door and locate the lower door seal on the bottom edge of the door. Gently pull the exposed edge of the seal away from bottom edge of the door and towards the dishwasher tub.
Removing the old seal
  • Now that the outer door panel is removed, you can open the door and locate the lower door seal on the bottom edge of the door.
  • Gently pull the exposed edge of the seal away from bottom edge of the door and towards the dishwasher tub.
Maintenant que vous avez retiré le panneau extérieur de la porte, ouvrez la porte et repérez le joint inférieur en bas de la porte.
Tirez délicatement le bord apparent du joint en direction de la cuve de lave-vaisselle pour le décoller du bord inférieur de la porte.
