Aller au contenu principal
Anglais
Français
Traduction de l’étape 4
Étape 4
Note that when installing the new seal there is an alignment tab located on the right hand side of the dishwasher (your right while facing the dishwasher). This tab needs to fit into the existing slot. If you have difficulty aligning this tab, you can remove the lower dishwasher rack to get a better view of the bottom side of the door.
Alignment tab placement
  • Note that when installing the new seal there is an alignment tab located on the right hand side of the dishwasher (your right while facing the dishwasher). This tab needs to fit into the existing slot. If you have difficulty aligning this tab, you can remove the lower dishwasher rack to get a better view of the bottom side of the door.
Lors de la pose du nouveau joint, repérez l'encoche d'alignement à droite du lave-vaisselle (sur votre droite quand vous regardez le lave-vaisselle). Cette encoche doit s'insérer dans le sillon qui correspond. Si vous avez du mal à les aligner, vous pouvez retirer le panier inférieur du lave-vaisselle pour mieux y voir.
