Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 14
Étape 14
At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips. If you've already verified that your iMac is working correctly and are ready to seal it up, skip to Step 16. Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely.
  • At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.
  • If you've already verified that your iMac is working correctly and are ready to seal it up, skip to Step 16.
  • Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely.
  • Flip the display data connector lock down onto the socket.
  • Insert the display power connector into its socket on the logic board.
Décollez et retirez la protection des bandes 15 et 14 sur l'écran.
[* black] Peelicon_note] ''At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.''
[* black] If you've already verified that your iMac is working correctly
and removeare ready to seal it up, skip to Step 16.
[* black] Gently insert
the backing from strips 15display data connector into its socket on the logic board. Be sure to press it straight into the socket, and 14insert it completely.
[* black] Flip the display data connector lock down onto the socket.
[* black] Insert the display power connector into its socket
on the displaylogic board.
