Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 43 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 20
Étape 20
Lift the display up to a near-vertical position. At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  • Lift the display up to a near-vertical position.
  • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  • Remove as much of the adhesive as possible by grabbing it at the outer edges, and then pulling or rolling it towards the middle.
Relevez l'écran jusqu'à ce qu'il soit presque vertical.
À ce stade, il reste une bande de mousse adhésive en bas de l'écran, qui maintient ensemble l'écran et le cadre comme une charnière. Vous pouvez la décoller en abaissant et en relevant l'écran plusieurs fois de suite.
[* black] Lift the display up to a near-vertical position.
[* icon_note] At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
[* black] Remove as much of the adhesive as possible by grabbing it at the outer edges, and then pulling or rolling it towards the middle.
