Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 43 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 10
Étape 10
Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner. Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
  • Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
  • Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
Bien que l'outil ait fait le plus gros du travail, il est probable que l'écran continue d'adhérer légèrement au boîtier. Vous aurez besoin d'une carte plastifiée pour découper le reste de la mousse adhésive.
Posez l'iMac à l'envers sur une table.
[* black] Gently twist the plastic card to open the space between the display and frame.
[* black] Move slowly
frame, and be careful not to stresscut any remaining adhesive near the display glasscorner.
[* icon_caution] Using
too much—you only needmuch force will crack the glass. Work carefully, and don't try to makecreate a gap ofany larger than about 1/4"1/4" (6 mm).
