Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
After the battery has been removed, use the spudger to disconnect the remaining ribbons. Notice that there are two side ribbons, one on each side (volume up/down and power), and a top ribbon as well as those from the battery compartment. Notice that there are two side ribbons, one on each side (volume up/down and power), and a top ribbon as well as those from the battery compartment.
Removal of Ribbons
  • After the battery has been removed, use the spudger to disconnect the remaining ribbons.
  • Notice that there are two side ribbons, one on each side (volume up/down and power), and a top ribbon as well as those from the battery compartment.
Une fois la batterie retirée, utilisez le spudger pour débrancher les rubans restants.
Notez qu'il existe deux rubans latéraux, un de chaque côté (volume haut / bas et alimentation), et un ruban supérieur ainsi que ceux du compartiment de la batterie.
[title] Removal of Ribbons
[* black] After the battery has been removed, use the spudger to disconnect the remaining ribbons.
[* red] Notice that there are two side ribbons, one on each side (volume up/down and power), and a top ribbon as well as those formfrom the battery compartment.
