Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 18 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case. The iSclack is designed to safely open your iPhone enough to separate the pieces, but not enough to damage any of the display cables.
  • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
  • The iSclack is designed to safely open your iPhone enough to separate the pieces, but not enough to damage any of the display cables.
  • Peel the two suction cups off your iPhone.
  • Skip the next three steps and continue on to Step 7.
Tenez bien votre iPhone et desserrez les poignées de l'iSclack pour séparer les ventouses et enlever la vitre du boîtier arrière.
Le iSclack est conçu pour ouvrir votre iPhone en toute sécurité, c'est à dire, sans risquer d'endommager les nappes de l'écran.
Décollez les deux ventouses de votre iPhone.
Sautez les trois prochaines étapes et continuez à l'étape 7
[* black] Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
[* icon_note] The iSclack is designed to safely open your iPhone enough to separate the pieces, but not enough to damage any of the display cables.
[* black] Peel the two suction cups off your iPhone.
[* black] '''Skip the next three steps and continue on [guide|29424|Step 7|stepid=69761]to Step 7.'''
