Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 18 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 9
Étape 9
Remove the following Phillips screws securing the front panel assembly cable bracket:
  • Remove the following Phillips screws securing the front panel assembly cable bracket:
  • Three 1.2 mm screws
  • One 1.5 mm screw
  • One 2.9 mm screw
  • Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.
Tout en tenant l'écran ouvert à un angle de 90°, enlevez les vis suivantes qui maintiennent le cache des connecteurs de l'écran :
Trois vis cruciformes Phillips #00 de 1,2mm
Une vis cruciforme Phillips #00 de 1,5mm
Une vis cruciforme Phillips #00 de 2,9mm
[* black] While holding the front panel open at about a 90º angle, removeRemove the following Phillips screws securing the front panel assembly cable bracket:
[* red] Three 1.2 mm Phillips #00 screws
[* orange] One 1.5 mm Phillips #00 screw
[* yellow] One 2.9 mm Phillips #00 screw
[* icon_caution] '''Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.'''
