Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Your next step is to remove the five screws holding down the motherboard.  Use the PH1 philips screwdriver. Once you have removed the five screws you may lift the motherboard off of the front case. At this point you may also remove the dial pad. It simply lifts off.
  • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
  • Once you have removed the five screws you may lift the motherboard off of the front case.
  • At this point you may also remove the dial pad. It simply lifts off.
  • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
  • The whole phone is now disassembled at this point.
Insérez ici votre traduction
