Aller au contenu principal
Anglais
Français
Traduction de l’étape 9
Étape 9
Solder small stranded wires torn out of a stranded cable. Pre-tin the leads so solder sticks more easily onto the copper. Do this by adding solder to tip of soldering iron, then rubbing across one of the ends of the replacement wire. Do this to both sides of all the wires, tin both the front and back each single end. The tin does not automatically flow to both sides, therefore tediously tin the front, then back of one side of wire.
  • Solder small stranded wires torn out of a stranded cable.
  • Pre-tin the leads so solder sticks more easily onto the copper. Do this by adding solder to tip of soldering iron, then rubbing across one of the ends of the replacement wire.
  • Do this to both sides of all the wires, tin both the front and back each single end. The tin does not automatically flow to both sides, therefore tediously tin the front, then back of one side of wire.
  • Shakey hands make this process hard.
Insérez ici votre traduction
