Aller au contenu principal
Remplacement de la batterie de l'iPhone 4
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 18 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
iPhone 4 Battery Replacement: étape 0, image 1 de 3 iPhone 4 Battery Replacement: étape 0, image 2 de 3 iPhone 4 Battery Replacement: étape 0, image 3 de 3
  • Use the clear plastic pull tab to gently lift the battery out of the iPhone.
  • If the tab breaks before the battery is freed, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery. Wait about one minute for the alcohol solution to weaken the adhesive. Carefully slide a spudger under the battery tab to release the adhesive.
  • Prying in other places may cause damage. Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
  • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
  • Before reconnecting the battery connector, be sure the contact clip (shown in red) is properly positioned next to the battery connector.
  • Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
  • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
En vous servant de la languette en plastique transparente, soulevez délicatement la batterie et retirez-la de l'iPhone.
Si la languette se brise avant que la batterie ne soit libérée, appliquez quelques gouttes d'alcool isopropylique (plus de 90 %) sous le bord de la batterie. Attendez une minute que la solution ramollisse l'adhésif. glissez soigneusement un spudger sous la languette de la batterie pour faire céder l'adhésif.
Le fait d'essayer à d'autres endroits peut causer des dommages. N’essayez pas de sortir la batterie par la force. Au besoin, appliquez quelques gouttes d’alcool de plus pour affaiblir davantage l’adhésif. Ne déformez ni perforez jamais la batterie avec votre outil de levier.
S’il reste de l’alcool dans le téléphone, essuyez-le soigneusement ou laissez-le sécher à l’air libre avant d’installer votre nouvelle batterie.
Si votre batterie de remplacement est livrée avec une protection plastique, enlevez-la avant d'installer la batterie en la décollant de la nappe.
Avant de rebrancher le connecteur de la batterie, assurez-vous que le clip de contact (en rouge) est correctement positionné à côté du connecteur de la batterie.
Avant le remontage, assurez-vous de bien nettoyer tous les points de contact métal sur métal avec un produit dégraissant tel que du windex. Le sébum sur vos doigts risque de causer des problèmes d'interférences sans fil.
Effectuez une réinitialisation matérielle (Hard Reset) après le remontage. Cela peut résoudre des problèmes.
