Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 7
Étape 7
Once all the adhesive has been separated, remove the home button from the front panel.
  • Once all the adhesive has been separated, remove the home button from the front panel.
  • If you are replacing a broken front panel, there may be glass shards stuck to the home button. Carefully remove any remaining glass before transferring your home button to a new display.
  • Your replacement part may come with an extra Phillips screw already installed left of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
Une fois la bande adhésive enlevée, retirer le bouton Home de l'écran.
Si la vitre que vous remplacez est brisée, il se peut qu'il y ait des bris de verre collés au bouton home. Retirez soigneusement les bris de verre avant de transférer le bouton home de l'ancien écran vers le nouveau.
[* black] Once all the adhesive has been separated, remove the home button from the front panel.
[* icon_note] If you are replacing a broken front panel, there may be glass shards stuck to the home button. Carefully remove any remaining glass before transferring your home button to a new display.
[* icon_reminder] Your replacement part may come with an [https://d3nevzfk7ii3be.cloudfront.net/igi/RBplrTYSIZiU3VDU|extra Phillips screw|new_window=true] already installed left of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
