Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 8
Étape 8
Slide the point of a spudger behind the shield plate to gently lift the home button cable up off of the front panel. If the cable doesn't peel away easily, use a little heat from an iOpener or hair dryer to soften the adhesive underneath. Remove the LCD shield plate.
  • Slide the point of a spudger behind the shield plate to gently lift the home button cable up off of the front panel.
  • If the cable doesn't peel away easily, use a little heat from an iOpener or hair dryer to soften the adhesive underneath.
  • Remove the LCD shield plate.
  • During reassembly, make sure to seat the home button connector on the shield behind the small indentation in the plastic.
Faites glisser une spatule (spudger) derrière la plaque de protection pour dégager délicatement la nappe du bouton home du panneau avant.
Si la nappe ne se décolle pas facilement, chauffez un peu en utilisant un iOpener ou un sèche-cheveux pour faire ramollir l'adhésif.
Retirez la plaque de protection LCD.
[* black] Slide the point of a spudger behind the shield plate to gently lift the home button cable up off of the front panel.
[* icon_caution] If the cable doesn't peel away easily, use a little heat from an iOpener or hair dryer to soften the adhesive underneath.
[* black] Remove the LCD shield plate.
+[* red] During reassembly, make sure to seat the home button connector on the shield behind the small indentation in the plastic.
