Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly. Very slowly, pull and stretch one adhesive strip away from the battery, toward the bottom of the iPhone.
  • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
  • Very slowly, pull and stretch one adhesive strip away from the battery, toward the bottom of the iPhone.
  • Allow the strip to stretch out before pulling any harder. If you can't feel it stretching, ease up, or it will break.
  • Pull at as low of an angle as you can without snagging the adhesive strip on any of the components along the lower edge of the phone.
  • Don't press down on the battery as you pull the strip.
  • The strip will stretch to many times its original length. Continue pulling slowly until it releases and slips out from underneath the battery.
  • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
  • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strips, and then proceed as instructed below.
Essayez de garder les bandes adhésives plates et non plissées pendant cette procédure. Les bandes plissées se collent ensemble et cassent au lieu de s'extraire proprement.
Retirez très délicatement la bande adhésive de la batterie en tirant vers le bas de l'iPhone.
Laissez la bande à s'étendre avant de tirer plus fort. Si vous ne la sentez pas s'étirer, relâchez la tension ou la bande adhésive se déchirera.
Tirez dans un angle aussi plat possible en évitant que la bande ne touche des composant le long de la partie basse du téléphone.
N'appuyez pas sur la batterie pendant que vous retirez la bande adhésive.
La bande adhésive va s'étirer sur plusieurs fois sa longueur initiale. Continuez à tirer doucement jusqu'à ce que la bande se libère et sorte de sous la batterie.
Si la bande adhésive se déchire, utilisez vos doigts ou une pincette arrondie pour récupérer le reste de la bande et continuez à tirer.
Si une des bandes adhésives se déchire en dessous de la batterie et que vous ne pouvez plus la récupérer, essayez d'enlever le reste de la bande et passez à procédez comme indiqué ci-dessous.
