Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 12 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 9
Étape 9
Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you. Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
  • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
  • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
  • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
Insérez ici votre traduction
