Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Peel back the final battery adhesive tab from the bottom edge of the battery. Gently pull the battery adhesive tab upward and away from the battery, allowing the adhesive strip to slowly slide out from between the battery and the rear case. Place one hand over the battery as the final strip comes out, or it may fling the battery out of the iPhone. Continue pulling until the final strip comes free from the iPhone.
  • Peel back the final battery adhesive tab from the bottom edge of the battery. Gently pull the battery adhesive tab upward and away from the battery, allowing the adhesive strip to slowly slide out from between the battery and the rear case.
  • Place one hand over the battery as the final strip comes out, or it may fling the battery out of the iPhone.
  • Continue pulling until the final strip comes free from the iPhone.
  • If you removed all three adhesive strips successfully, continue to step 24. Otherwise, if the adhesive breaks off underneath the battery and can't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
  • Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
  • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  • Do not pry against the logic board, or you may permanently damage your iPhone. Do not pry under the topmost section of the battery, near the volume up button and mute switch, or you may damage the audio controls cable, which is adhered to the rear case just beneath the battery.
  • For alternative methods to unstick the battery, continue with the next step below.
Décollez la dernière bande adhésive du côté inférieure de la batterie.
Tirez la bande adhésive lentement vers le haut et en s'éloignant du côté gauche de la batterie, jusqu'à ce que la bande est complètement enlevée de l'espace entre la batterie et le boîtier arrière.
Placez une main sur la batterie lorsque vous finissez d'enlever la dernière bande pour éviter que la batterie ne soit catapultée en dehors de l'iPhone.
Continuez à décollez la bande adhésive jusqu'à ce qu'elle soit complètement enlevée.
Si vous avez décollé les trois bandes adhésives sans problèmes, sautez les deux prochaines étapes.
Si l'une des bandes adhésives s'est déchirée en dessous de la batterie et que vous ne pouvez pas la récupérer, continuez avec l'étape suivante.
[* black] Peel back the final battery adhesive tab from the bottom edge of the battery.
[* black]
[* black]
[* icon_caution] Place one hand over the battery as the final strip comes out, or it may fling the battery out of the iPhone.
[* black] Continue pulling until the final strip comes free from the iPhone.
[* black[* icon_note] If you removed all three adhesive strips successfully, '''[guide|29424|skip over the next two steps|stepid=69610]'''.
[* icon_caution] If any of
continue to '''step 24'''. Otherwise, if the adhesive strips brokebreaks off underneath the battery and could notcan't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
[* black] Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
[* icon_caution] Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
[* icon_caution] '''Do not''' pry against the logic board, or you may permanently damage your iPhone. '''Do not''' pry under the topmost section of the battery, near the volume up button and mute switch, or you may damage the [guide|31183|audio controls cable|stepid=74381|new_window=true], which is adhered to the rear case just beneath the battery.
[* icon_note] For alternative methods to unstick the battery,
'''continue with the next step below'''.
