Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 2
Étape 2
Make sure that the clip used to release the side panel is open or the Hard Drive bays won't slide out Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove. Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove.
Remove the Hard Drive Bay
  • Make sure that the clip used to release the side panel is open or the Hard Drive bays won't slide out
  • Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove.
Vérifiez bien que le loquet est bien relevé, sinon le tiroir ne glissera pas.
Retirez le tiroir à disque dur à l'horizontale en le saisissant par le bas. Il peut être difficile à retirer au début, mais une fois débloqué, il ne devrait pas être difficile de le retirer.
