Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 8 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover. Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
  • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
Localisez le creux utilisé lors des étapes précédentes.
Soulevez doucement en utilisant vos doigts.
[* yellow] Locateblack] Insert a thumbnail, or a prying tool like a spudger, into the same gap used innotch at the bottom left of the back cover you used earlier stepto remove the back cover.
[* black] Lift gently using your fingersPry up the plastic panel, including the loudspeaker, until you can get a good grip.
