Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard. Pry up the motherboard cover to open the plastic clips which hold the cover in its place. The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
  • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
  • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
  • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
  • Work your way along the right edge.
Insérez ici votre traduction
