Aller au contenu principal
Anglais
Français
Traduction de l’étape 11
Étape 11
Next, proceed by removing all of the cables that connect to the DMD board. At the upper right edge there is a small ribbon cable that pulls straight up to remove, and two other cables that connect with cable ends that clip in to the small plugs. Remove these three cables carefully. Next, remove the three cables on the right end of the DMD board. The two upper are fan power cables, and the lower connects to the light bulb controls.
  • Next, proceed by removing all of the cables that connect to the DMD board.
  • At the upper right edge there is a small ribbon cable that pulls straight up to remove, and two other cables that connect with cable ends that clip in to the small plugs. Remove these three cables carefully.
  • Next, remove the three cables on the right end of the DMD board. The two upper are fan power cables, and the lower connects to the light bulb controls.
  • Finally, remove the lower most cable that connects to the bottom left corner of the DMD board.
Insérez ici votre traduction
