Aller au contenu principal
Anglais
Français
Traduction de l’étape 13
Étape 13
Remove the four spring-loaded screws that reside on each side of the heatsink. These screws apply pressure to the DMD board to hold it in position, under tension - once adjusted at the factory the the DMD board needs to be held in place over the long term or the picture quality will suffer. See the springs that sit behind the screws in the second picture.
  • Remove the four spring-loaded screws that reside on each side of the heatsink. These screws apply pressure to the DMD board to hold it in position, under tension - once adjusted at the factory the the DMD board needs to be held in place over the long term or the picture quality will suffer.
  • See the springs that sit behind the screws in the second picture.
Insérez ici votre traduction
