Aller au contenu principal
Anglais
Français
Traduction de l’étape 21
Étape 21
Turn the DMD board over and you will see the DLP chip. If you've ever removed a computer CPU you will find this is a bit different. The chip is not held in with a "Zero Insertion Force" mechanism with a clip or lever. Instead, it is held in by the tension of the pins alone.
  • Turn the DMD board over and you will see the DLP chip.
  • If you've ever removed a computer CPU you will find this is a bit different. The chip is not held in with a "Zero Insertion Force" mechanism with a clip or lever. Instead, it is held in by the tension of the pins alone.
  • Therefore, when removing the chip, simply pull up until it releases from the board.
Insérez ici votre traduction
