Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 16 tutoriels qui comprennent cette étape.
Traduction de l’étape 2
Étape 2
Lift the top cover from its rear edge and rotate it toward the front of the PS3.
Remove the top cover.
There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit front the rear of the machine with a spudger to release the rear right of the casing.
[* black] Lift the top cover from its rear edge and rotate it toward the front of the PS3. |
[* black] Remove the top cover. |
[* black] There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit front the rear of the machine with a spudger to release the rear right of the casing. |
