Aller au contenu principal
Anglais
Français
Traduction de l’étape 7
Étape 7
Do not use alcohol unless you are out of options. This may damage the printhead! Purge the printhead 3 times if alcohol is used to avoid problems. Recommended circulation times: Alcohol: 5-10 minutes. Without alcohol: 15 minutes.
Clean the printhead
  • Do not use alcohol unless you are out of options. This may damage the printhead! Purge the printhead 3 times if alcohol is used to avoid problems.
  • Recommended circulation times: Alcohol: 5-10 minutes. Without alcohol: 15 minutes.
  • The water will get lighter as the ink breaks down. An ultrasonic cleaner can be used on stubborn clogs.
  • Pour hot water into a bowl and let the printhead sit. Change the water until the printhead is reasonably clean.
  • Dry the printhead contacts and nozzles by hand to ensure these areas are dry.
  • Before reinstalling the printhead, let it air dry for ~3-4 hours. Use a fan to reduce the dry time.
Insérez ici votre traduction
