Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 10 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Lift the back cover to release the rest of the plastic clips and remove it. In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
  • Lift the back cover to release the rest of the plastic clips and remove it.
  • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
  • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
Commencez par enlever la coque arrière du téléphone en utilisant le creux situé en bas à gauche du smartphone.
Insérez un outil d'ouverture en plastique dans le creux et déplacez le le long des bords du téléphone jusqu'à ce que la façade arrière s'enlève.
[* red] Start by liftingblack] Lift the back panel usingcover to release the gap located on the bottom-left siderest of the phone.
[* black] Insert
the plastic openingclips and remove it.
[* icon_note] In case you can't lift the back cover completely, slide your fingernail or your prying
tool intoaround the gap and move it alongmidframe to release the edge ofremaining clips.
[* icon_reminder] To reinstall
the phoneback cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear case pops offside of the phone.
[* black] Insert
