Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 7
Étape 7
Push down on the small tab and pull the connector directly away from its socket to disconnect the power lock switch. Use the same method described above to remove the connector for the tweeter. Press the tab on the bottom of the larger green connector to disconnect the side-view mirror controls.
  • Push down on the small tab and pull the connector directly away from its socket to disconnect the power lock switch.
  • Use the same method described above to remove the connector for the tweeter.
  • Press the tab on the bottom of the larger green connector to disconnect the side-view mirror controls.
Insérez ici votre traduction
