Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 7
Étape 7
Push down on the small tab and pull the connector directly away from its socket to disconnect the power lock switch. Use the same method described above to remove the connector for the tweeter. Press the tab on the bottom of the larger green connector to disconnect the side-view mirror controls.
  • Push down on the small tab and pull the connector directly away from its socket to disconnect the power lock switch.
  • Use the same method described above to remove the connector for the tweeter.
  • Press the tab on the bottom of the larger green connector to disconnect the side-view mirror controls.
Insérez ici votre traduction
