Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture. Before starting, be sure to clean the display glass with lint-free cloth moistened with a mild solution; it will make the suction cup adhere better, and will make checking for dust on reassembly easier
  • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
  • Before starting, be sure to clean the display glass with lint-free cloth moistened with a mild solution; it will make the suction cup adhere better, and will make checking for dust on reassembly easier
  • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
  • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
  • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
Au cours des étapes suivantes, vous aurez besoin d'une pistolet à air chaud pour ramollir la colle fixant la bordure extérieure noire à l'écran tout le long de la face intérieure de la vitre avant. La zone où la colle a été mise est marquée en rouge sur la seconde photo.
Avant de commencer, veillez à nettoyer la vitre avec un chiffon non pelucheux humidifié avec une solution lavante douce ; cela permettra à la ventouse à levier de mieux adhérer et à vous de vérifier plus facilement l'absence de poussière lors du remontage.
Réglez le pistolet à air chaud à température basse et commencez à chauffer la bordure extérieure noire, du côté du coin supérieur droit de l'écran.
Ne pointez jamais le pistolet sur la bande souple en caoutchouc le long de la vitre. Si vous chauffez le caoutchouc, vous risquez de le faire fondre légèrement et de rendre brillante sa surface matte. Si vous touchez le caoutchouc surchauffé, vous risquez de le déformer définitivement.
Pendant que vous chauffez, il est normal qu'une couche de condensation se forme à l'intérieur de la vitre et/ou à l'extérieur de l'écran LCD. Vous pouvez l'enlevez avec du nettoyant pour vitres une fois que la vitre est séparée de l'écran.
