Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 3 tutoriels qui comprennent cette étape.
Traduction de l’étape 2
Étape 2
Flip the iPad back over and insert a plastic card under the battery cell nearest the logic board and right speaker.
- | [* icon_caution] Throughout the following procedure, you'll be sliding thin plastic |
+ | [* icon_caution] Throughout the following procedure, you'll be sliding thin [product|IF145-101|plastic card]s between the battery and rear case of the iPad to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals. |
[* black] Flip the iPad back over and insert a plastic card under the battery cell nearest the logic board and right speaker. | |
[* icon_note] If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften. |
