Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 10
Étape 10
In order to remove the upper LCD and the cameras from the front bezel, it is helpful to coil the ribbon cables together. Carefully coil the two ribbon cables together, so that the connectors are on the inside of the spool.
  • In order to remove the upper LCD and the cameras from the front bezel, it is helpful to coil the ribbon cables together.
  • Carefully coil the two ribbon cables together, so that the connectors are on the inside of the spool.
  • Wrap the ribbon cables tightly, but not too tight, as bending the connectors will render them inoperable.
Insérez ici votre traduction
