Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 3
Étape 3
Disconnect the connector that includes all of the power and signal wires from the back of the head unit by first pushing down on the small tab on top of the connector, and then pulling straight out. Remove the radio antenna cable from the back of the head unit by pulling it straight out.
  • Disconnect the connector that includes all of the power and signal wires from the back of the head unit by first pushing down on the small tab on top of the connector, and then pulling straight out.
  • Remove the radio antenna cable from the back of the head unit by pulling it straight out.
  • With these two things removed, the entire head unit can be pulled out of the dash.
  • When installing the new stereo, make sure that the speaker and signal wires are not getting in the way of the head unit sliding all the way into place.
  • If you are installing an after-market head unit, you don't need to reuse the two Phillips screws, because the adapter bracket for the head unit will clip into the dash.
Insérez ici votre traduction
