Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 12 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket. Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
  • Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
  • Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
Utilisez l'extrémité plate d'un spudger pour soulever le connecteur de la nappe de la vitre tactile tout droit hors de sa prise.
[* black] Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
[* icon_caution] Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
