Aller au contenu principal
Anglais
Français
Traduction de l’étape 5
Étape 5
Remove the five 8.4mm phillips screws securing the Blu-ray control board to the Blu-ray drive. Be sure to also remove the metal ground springs from under the screws in the corners.
  • Remove the five 8.4mm phillips screws securing the Blu-ray control board to the Blu-ray drive.
  • Be sure to also remove the metal ground springs from under the screws in the corners.
Retirez les cinq vis Phillips 8.4mm qui maintiennent le tableau de contrôle au lecteur Blu-ray.
Faites attention de retirer également les ressorts en métal d´en dessous des vis dans les coins.
