Anglais
Français
Traduction de l’étape 2
Étape 2
Pull the distributor rotor straight off its shaft, being careful not to rotate the shaft as you remove it. When installing the new distributor rotor, press it onto the shaft with the screw holes aligned axially.
  • Pull the distributor rotor straight off its shaft, being careful not to rotate the shaft as you remove it.
  • When installing the new distributor rotor, press it onto the shaft with the screw holes aligned axially.
Insérez ici votre traduction
