Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Turn the tablet off before beginning  this guide. It is dangerous to touch internal components while the tablet is on. Place the tablet on its screen and use the opening tool to remove the back cover.
Battery
  • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
  • Place the tablet on its screen and use the opening tool to remove the back cover.
  • With the tool, place slight pressure on the tablet to pry the back panel off.
Assurez-vous que la tablette est éteinte avant de commencer cette procédure. Il est dangereux de toucher les composants internes de l'électronique alors qu'ils sont encore allumés.
Placez la tablette sur son écran et utilisez le grand outil d’ouverture en plastique pour retirer le capot arrière.
Appliquez une légère pression sur la tablette lorsque vous utilisez l’outil pour soulever le panneau arrière.
-[title] Removing the Cover
-[* icon_caution] Make sure that the tablet is powered off before beginning this procedure. It is dangerous to touch the internal components of electronics while they are still powered on.
-[* black] Place the tablet on its screen and use the large plastic opening tool to remove the back cover.
-[* black] Place slight pressure on the tablet while using the tool to pry the back panel off.
+[title] Battery
+[* icon_caution] Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
+[* black] Place the tablet on its screen and use the opening tool to remove the back cover.
+[* black] With the tool, place slight pressure on the tablet to pry the back panel off.
