Aller au contenu principal
Anglais
Français
Traduction de l’étape 5
Étape 5
Solvents used for cleaning brake hardware are harmful to skin. Always wear gloves when dealing with these chemicals. Thoroughly spray the inside of the brake drum with a brake cleaning solvent. Once the solvent has had a chance to work its magic (10 minutes or so), use a rough-grit sandpaper (100 grit or so) to clean the inner diameter of the drum. Rinse and repeat until you are satisfied with the cleanliness of the drum.
  • Solvents used for cleaning brake hardware are harmful to skin. Always wear gloves when dealing with these chemicals.
  • Thoroughly spray the inside of the brake drum with a brake cleaning solvent.
  • Once the solvent has had a chance to work its magic (10 minutes or so), use a rough-grit sandpaper (100 grit or so) to clean the inner diameter of the drum. Rinse and repeat until you are satisfied with the cleanliness of the drum.
Insérez ici votre traduction
