Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 16 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Lift the top cover from its rear edge and rotate it toward the front of the PS3.
  • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
  • Remove the top cover.
  • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit front the rear of the machine with a spudger to release the rear right of the casing.
Soulevez le couvercle supérieur par le bord arrière et faites-le pivoter vers l'avant de la PS3.
Enlevez le couvercle supérieur.
[* black] Lift the top cover from its rear edge and rotate it toward the front of the PS3.
[* black] Remove the top cover.
[* black] There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit front the rear of the machine with a spudger to release the rear right of the casing.
