Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 1
Étape 1
Use the edge of an iPod opening tool to peel the adhesive under the battery that secures it to the logic board. Flip the battery upwards to reveal the solder pads soldered to the logic board.
  • Use the edge of an iPod opening tool to peel the adhesive under the battery that secures it to the logic board.
  • Flip the battery upwards to reveal the solder pads soldered to the logic board.
  • Before desoldering the battery, be sure to scrape the protective resin off both solder points.
  • Desolder the battery from the logic board by heating up the solder joint with a soldering iron and simultaneously using a pair of tweezers to pull the battery wire away from the logic board.
  • Do not touch the + and - leads together.
  • If you have never soldered before, we have a guide that makes it easy.
Insérez ici votre traduction
