Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 8
Étape 8
Remove both of these wires. The LCD one is a push-on connector and the Digitizer has a small retaining clip. Be careful that you do not break it while trying to open it. This is where patience will pay off. Gently remove the motherboard ensuring that all the connections are loose.
  • Remove both of these wires. The LCD one is a push-on connector and the Digitizer has a small retaining clip. Be careful that you do not break it while trying to open it. This is where patience will pay off. Gently remove the motherboard ensuring that all the connections are loose.
Retirez les deux fils. Le LCD est un connecteur enfichable et le Digitizer a un petit clip de retenue. Veillez à ne pas le casser en essayant de l'ouvrir. C'est là que la patience sera payante. Retirez délicatement la carte mère en veillant à ce que toutes les connexions sont lâches.
