Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
Once the case is off, hold down the ribbon near the LCD screen that connects the flash to the camera. While doing this, carefully lift the control board that contains the flash until the ribbon is no longer connected. Once the case is off, hold down the ribbon near the LCD screen that connects the flash to the camera. While doing this, carefully lift the control board that contains the flash until the ribbon is no longer connected. Once the case is off, hold down the ribbon near the LCD screen that connects the flash to the camera. While doing this, carefully lift the control board that contains the flash until the ribbon is no longer connected.
  • Once the case is off, hold down the ribbon near the LCD screen that connects the flash to the camera. While doing this, carefully lift the control board that contains the flash until the ribbon is no longer connected.
Une fois le boîtier éteint, maintenez le ruban près de l'écran LCD qui relie le flash à l'appareil photo. Tout en faisant cela, soulevez soigneusement la carte de contrôle qui contient le flash jusqu'à ce que le ruban ne soit plus connecté.
