Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 19 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi. Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing. Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
  • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
  • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Insérez la spatule (spudger) entre le boîtier inférieur et le panneau inférieur à côté du coin supérieur droit de la DSi.
Parcourez soigneusement avec la spatule le bord du boîtier inférieur. Vous ouvrez ainsi une fente entre le boîtier et le reste de la DSi.
Continuez à parcourir avec la spatule le pourtour de la DSi jusqu'à avoir séparé la plus grande partie du boîtier inférieur.
[* red] Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
[* blueorange] Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
[* blueorange] Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
