Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 19 tutoriels qui comprennent cette étape.
Traduction de l’étape 4
Étape 4
Carefully lift the lower casing from its bottom edge.
Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
Once the cable is completely removed, then you may take off the entire outer casing.
[* icon_caution] The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet. |
[* orange] Pry the volume and SD board cable up from its socket on the motherboard [* orange] |
