Aller au contenu principal
Remplacement du boitier du Sony Cyber-shot DSC-W570
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Sony Cyber-shot DSC-W570 Case Cover Replacement: étape 0, image 1 de 2 Sony Cyber-shot DSC-W570 Case Cover Replacement: étape 0, image 2 de 2
  • Flip the device, making sure the screen is facing upwards
  • The back case should now be visible and ready to remove
  • Use the plastic opening tool to gently pry all along the corners and sides of the camera.
  • Gently lift off the entire back cover and place it on the side
Pour retirer le couvercle du boîtier arrière du corps.
Utilisez d'abord un outil d'ouverture en plastique, faites doucement levier le long du côté de la caméra.
Puis soulevez lentement et doucement le couvercle.
-[* black] To remove the back case cover from the body.
-[* black] First use a plastic opening tool gently pry along the side of the camera.
-[* black] Then slowly and gently lift the cover off.
+[* black] Flip the device, making sure the screen is facing upwards
+[* icon_note] The back case should now be visible and ready to remove
+[* black] Use the plastic opening tool to gently pry all along the corners and sides of the camera.
+[* black] Gently lift off the entire back cover and place it on the side
