Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
Using a plastic spudger depress the pins holding the RAM in. If you  have an anti-static work surface or wristband, you may suppress the pins with your thumbs. Static charge built up on surfaces contacting the RAM or other computer components can damage and destroy the components.  Always discharge yourself before handling these components! Pull the RAM straight out.
  • Using a plastic spudger depress the pins holding the RAM in. If you have an anti-static work surface or wristband, you may suppress the pins with your thumbs.
  • Static charge built up on surfaces contacting the RAM or other computer components can damage and destroy the components. Always discharge yourself before handling these components!
  • Pull the RAM straight out.
Insérez ici votre traduction
