Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 2
Étape 2
Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
  • Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
  • The tray will partially pop out of the laptop.
  • Firmly pull the drive straight away from the laptop.
  • While pulling the drive out, be careful not to bend the sliding rails on both sides of the optical drive.
  • At this point you can remove the entire optical drive, or you can continue to disassemble the optical drive assembly.
Insérez ici votre traduction
