Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 3
Étape 3
Remove the motherboard from the tabs and gently lift it out of the case. Remove the yellow NFC module that is attached to the motherboard from the plastic casing with tweezers. Remove the motherboard from the tabs and gently lift it out of the case. Remove the yellow NFC module that is attached to the motherboard from the plastic casing with tweezers.
  • Remove the motherboard from the tabs and gently lift it out of the case. Remove the yellow NFC module that is attached to the motherboard from the plastic casing with tweezers.
Insérez ici votre traduction
