Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 2
Étape 2
The aim here is to sandwich thick thermal pads under you MacBook's heatsinks to contact the upper case, and atop them to contact the bottom cover.  This will help conduct heat away from the machine by effectively making the entire unibody one big heatsink. On my machine, a mid-2010 15 inch MBP, I needed to use three strips of a 2mm thick thermal pad under the centre heatsink, two strips under the side one and one strip atop each to make contact with the bottom cover. Try to use enough layers that the heatsinks are in good contact, but not so many that anything needs to bend to fit back.
Thermally bonding the heatsinks
  • The aim here is to sandwich thick thermal pads under you MacBook's heatsinks to contact the upper case, and atop them to contact the bottom cover. This will help conduct heat away from the machine by effectively making the entire unibody one big heatsink.
  • On my machine, a mid-2010 15 inch MBP, I needed to use three strips of a 2mm thick thermal pad under the centre heatsink, two strips under the side one and one strip atop each to make contact with the bottom cover.
  • Try to use enough layers that the heatsinks are in good contact, but not so many that anything needs to bend to fit back.
Le but ici est d'intercaler d'épais tampons thermiques sous les dissipateurs du MacBook entre le boîtier supérieur et le couvercle inférieur. Cela aidera à évacuer la chaleur de la machine en transformant effectivement l'ensemble de la monocoque en un gros dissipateur thermique.
Sur ma machine, MBP 15 pouces mi-2010 , j'ai eu besoin de trois bandes d'un tampon thermique de 2 mm d'épaisseur sous le dissipateur central, deux bandes sous le latéral et une bande au sommet de chaque pour créer le contact avec le couvercle inférieur.
Essayez d'utiliser assez de couches pour que les dissipateurs soient bien en contact, mais pas trop pour que tout puisse se réinstaller sans plier.
