Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Traduction de l’étape 1
Étape 1
Unscrew the Fan
Turn the Wii mini around so that the back of the device is facing you.
Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece.
[title] Unscrew the Fan | |
[* black] Turn the Wii mini around so that the back of the device is facing you. | |
[* red] Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece. | |
- | [* icon_note] You may need to use tweezers to pull out the screws once they are loosened. |
+ | [* icon_note] You may need to use [product|IF145-020|tweezers] to pull out the screws once they are loosened. |
