Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 16
Étape 16
Remove the final screw holding the motherboard in place. Then gently lift the motherboard up vertically. Remove the two marked cables. These will be tight. Do not pull by the wires. Carefully wiggle the connectors only. Remove the final data cable near the front of the system board. The motherboard will be free. Lift up and towards the left to remove from the base.
  • Remove the final screw holding the motherboard in place. Then gently lift the motherboard up vertically.
  • Remove the two marked cables. These will be tight. Do not pull by the wires. Carefully wiggle the connectors only.
  • Remove the final data cable near the front of the system board. The motherboard will be free. Lift up and towards the left to remove from the base.
Insérez ici votre traduction
