Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod. You may need to rock the pick back and forth to slide it in farther. Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
  • Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
  • You may need to rock the pick back and forth to slide it in farther.
  • Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
  • Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
  • After all five tabs along the right side are free, the case should open easily.
Insérez ici votre traduction
